This FAQ describes how to import a 3D model into SaaS Composer.
Brief Solution - Step by Step:
Go to your file directory, create a folder named “assets”.
Drag your obj and mtl file into “assets” folder
Compress the whole folder to a .zip file. In here we use “station.zip” as an example
Go to your 3D SaaS Composer sketchboard, select “Assets” tab, click the import button.
Browse the target file.
After the files are imported, you can see the .obj and .mtl files in assets tab.
Right Click the menu icon, and select New Model => OBJ Model
Copy and paste the obj and mtl file location.
Specify a name of your model, and press Save.
Go to model tab, we can see the model “Train” is created.
Drag the model onto your sketchboard, the model can be applied on the sketchboard
