Q:
Using WISE-6610 as sensor gateway to receive data from WISE-4610 sensor node. After receiving the data from the sensor node, try to use Node-red to establish an MQTT connection by using the RabbitMQ secret provided in the namespace.
Which information from the secret shall provide in the following columns (server, username & password)?
A:
Checking RabbitMQ in portal-service and get MQTT connection certificate in secret.
- Link to portal-service
- Select RabbitMQ
- Create secret
- View secret and get credentials
- host : External Hosts
- port : mqtt.port
- username : mqtt.username
- password : mqtt.password
