Indeed, it is tough, but not impossible,
Customers are paying more and more attention to carbon emissions and energy tracking, but they have no way of knowing the energy and carbon emissions used in production.
How to resolve it?
Tip No 1. To get the data in the easiest approach
collecting meter(RS 485)/PLC(Mitsubishi/Siemens/Rockwell…) in one small box is not a hard job for Advantech ECU-1051. It plays a decent role in enabling the data collection.
Tip No 2. Measure the data and transform it into an insightful way, we call it “parameter set & data transform”, Yes, you want to read total energy consumption per hour or per work shift, but you need to transform the raw data into the higher level of information. Our parameter set will help do it.
*slide credit to Advantech Europe IoT consultant Niklas
Tip No 3. create KPI
having the calculated data and organizing a meaningful KPI will require your expertise & the way to manage your production line, but we have tools for you to develop.
Tip the last: visualized it
Our pre-made dashboard template can help you out in the initial phase, and freely to adjust it in any time you have new ideas.
Voilà! now you have your machine production & energy usage both on track.
