This FAQ mainly explains how to set up the anonymous login function of Local WISE-PaaS Dashboard
Figure 1: anonymous login
Step1: Go to IOTedge data source to setup anonymous
Step2: Go to sever admin to setup anonymous
Brief Solution - Step by Step:
1. Go to IOTedge data source setup anonymous.
Make sure IP correct.
Make sure user name and password correct.
Account and password Ex :
Customer@2025
2. Login Server Admin
3. confirm Auth.anonymous enabled is true
4. click Org_name
click Org_nameEdit
5. choose Org_name, use MPDefaultGroup as example
Org_name choose “MPDefaultGroup” → Add → add ” MPDefaultGroup” into Org_name → close
6. back to Server Admin
7. Go to Server Admin’s top , click refresh then will work (important)
8. Back to Dashboard confirm URL http://172.16.8.61:10015/frame/Demo?orgId=2&language=en-US&theme=gray&panelTitleShow=false
Can see SRPframe Dashboard anonymously
