Device went offline on WISE-IOT dashboard after previously working correctly. It worked properly until last friday when all the devices went offline. No configuration changes were made before Friday.
Error log on system log in ECU-1051’s web interface:
Sep 22 15:00:28 ecu1051-d30fb1 user.notice MQTTClient: [mcm_WISE-PaaS.c:2466:get_mqtt_credential] DCCS request begin…
Sep 22 15:00:29 ecu1051-d30fb1 user.notice MQTTClient: [mcm_WISE-PaaS.c:2479:get_mqtt_credential] DCCS request end with rc = 0 (No error), HTTP RESPONSE CODE = 200
Sep 22 15:00:29 ecu1051-d30fb1 user.notice MQTTClient: [mcm_WISE-PaaS.c:2789:get_mqtt_conn_cfg] got credential: {“serviceName”:“RabbitMQ”,“serviceHost”:“iot-bus.practice.cloud.advantech.com”,“serviceKeyName”:“03243f2fa2da4deac6adb619d701a4x3”,“serviceKeyGuid”:"b8c7f46e-f065-441
Sep 22 15:00:29 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:493:comm_mqtt_connect] [iot-bus.practice.cloud.advantech.com:8883:(null)] mqtt_version = 4, will = 0x16164e8, sock5_proxy = (nil), username = NE8Q4MpPDVe0:dgqMA08GWZqb, password = 6yWBR4vhmc4zkRh0tE6F, ssl_enab
Sep 22 15:00:29 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:588:comm_mqtt_connect] [iot-bus.practice.cloud.advantech.com:8883:(null)] mosquitto_will_set topic = /wisepaas/scada/1de1e3c991bd4bb09ba394b467ab3f97/conn, payload_len = 47, qos = 1, retain = 0, payload = {“d”:
Sep 22 15:00:29 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:399:init_ssl_option] [iot-bus.practice.cloud.advantech.com:8883:(null)] insecure = 1, scenario = 0, cert_reqs = 0, version = tlsv1.2, ca_file = /home/sysuser/project/default-ca-certificates.crt, cert_file = (nu
Sep 22 15:00:29 ecu1051-d30fb1 user.err MQTTClient: [comm_mqtt.c:409:init_ssl_option] [iot-bus.practice.cloud.advantech.com:8883:(null)] mosquitto_tls_insecure_set 1 return 0 (No error.)
Sep 22 15:00:29 ecu1051-d30fb1 user.err MQTTClient: [comm_mqtt.c:424:init_ssl_option] [iot-bus.practice.cloud.advantech.com:8883:(null)] mosquitto_tls_opts_set cert_reqs=0 tls_version=tlsv1.2 return 0 (No error.)
Sep 22 15:00:29 ecu1051-d30fb1 user.err MQTTClient: [comm_mqtt.c:442:init_ssl_option] [iot-bus.practice.cloud.advantech.com:8883:(null)] mosquitto_tls_set cafile(/home/sysuser/project/default-ca-certificates.crt) capath(nil) certfile(nil) keyfile(nil) return 0 (No error.)
Sep 22 15:00:29 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:666:comm_mqtt_connect] [iot-bus.practice.cloud.advantech.com:8883:(null)] connecting …
Sep 22 15:00:30 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:79:on_mosquitto_log] [E] [iot-bus.practice.cloud.advantech.com:8883:(null)] OpenSSL Error[0]: error:0A0C0103:SSL routines::internal error
Sep 22 15:00:30 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:266:on_mqtt_disconnect] [iot-bus.practice.cloud.advantech.com:8883:(null)] rc = 14, msg = Connection Refused: unknown reason.
Sep 22 15:00:30 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:79:on_mosquitto_log] [E] [iot-bus.practice.cloud.advantech.com:8883:(null)] OpenSSL Error[0]: error:0680009F:asn1 encoding routines::unexpected eoc
Sep 22 15:00:30 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:79:on_mosquitto_log] [E] [iot-bus.practice.cloud.advantech.com:8883:(null)] OpenSSL Error[1]: error:0688010A:asn1 encoding routines::nested asn1 error
Sep 22 15:00:30 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:79:on_mosquitto_log] [E] [iot-bus.practice.cloud.advantech.com:8883:(null)] OpenSSL Error[2]: error:0A08000D:SSL routines::ASN1 lib
Sep 22 15:00:59 ecu1051-d30fb1 user.warn MQTTClient: [mqtt_conn.c:2661:mqtt_conn_proc] [9dfa7b24-ff01-4a32-ab0f-c9cb55ca7771] connection timeout, tick = 7437827!
Sep 22 15:00:59 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:762:comm_mqtt_disconnect] [iot-bus.practice.cloud.advantech.com:8883:(null)] enter
Sep 22 15:00:59 ecu1051-d30fb1 user.notice MQTTClient: [comm_mqtt.c:782:comm_mqtt_disconnect] [iot-bus.practice.cloud.advantech.com:8883:(null)] leave
Sep 22 15:00:59 ecu1051-d30fb1 user.err MQTTClient: [comm_mqtt.c:711:comm_mqtt_connect] [iot-bus.practice.cloud.advantech.com:8883:(null)] connect timeout!
Sep 22 15:00:59 ecu1051-d30fb1 user.warn MQTTClient: [mqtt_conn.c:2478:mqtt_conn_connect_proc] [9dfa7b24-ff01-4a32-ab0f-c9cb55ca7771] connect failed, rc = -692!
I ran some troubleshooting, I found that the DCCS authentication succeeds every time
Failure only occurs after DCCS authentication, during the TLS handshake
If any of you know how to fix this issue, please reply this. Thank you
