POST beep test for Advantech PCM 9375 Biscuit PC
I have a PCM 9375 that on book provides a POST beep code of 7 6 6 (DECIMAL) after which it emits a continuous tone. I cannot find this POST code listed. Can you please advise what it indicates.
Hi there,
This forum is to focus on software maintenance.
According to your hardware question, please use the link below to find corresponding contact window.
Contact us in Worldwide - Advantech
Thanks
The 7-6-6 POST code on your PCM-9375 isn’t a standard beep code and likely comes from a debug card showing decimal values. It usually indicates a serious hardware fault often memory or CPU related. The continuous tone afterward also points to a hardware failure; try reseating RAM and checking CPU connections.
